Air/Fuel monitoring
Postby Rob Henderson » Thu May 16, 2019 4:33 pm
Hi all
I would like to connect a Air Fuel O2 Sensor to an analog input.
The sensor outputs 0v-5v for 10-20 a/f.
any suggestions as to where to begin programming?
thanks
Rob Henderson
Re: Air/Fuel monitoring
Postby GRT_Jeff » Fri May 17, 2019 4:51 am
To convert 0V-5V to an integer 10-20:
Analog # Scale Factor: 5
Analog # Offset: 20
Analog # Sensing: Forward
Analog # Integer/Decimal: Integer
Analog # Aux Function: Aux
Analog # Aux Name: A/F
Optional:
For one decimal place, multiply the scale factor and offset by 10 and configure it for Decimal mode.
Postby Rob Henderson » Sun May 19, 2019 4:20 am
Works perfectly
Rob Henderson
