Analog inputs
Roger
Analog inputs
Post by Roger »
Can a simple linear pot be used as a sensor for flap or trim position? If so what is the recommended value? I understand that the HX unit has a pull up that can be turned on so no voltage needs to be applied to the sensor device.
Re: Analog inputs
Post by Bobturner »
The simple answer is yes. The linear variable resistor units from Ray Allen work well, no external bias needed. I think they are a few Kohms max.
Roger
Re: Analog inputs
Post by Roger »
Does anyone know the resistance value of these pots?
Re: Analog inputs
Post by Bobturner »
Ray Allen units are 0 to 5 K.
Roger
Re: Analog inputs
Post by Roger »
Thanks Bob
