Screen Dimming
Posted: Sat Apr 06, 2013 11:19 pm
by jkreidler
We do not use an external dimmer to set the screen brightness. Even set to 1 the screen is too bright on a dark night, is there a way to get the careen dimmer? Thanks - Jason
Re: Screen Dimming
Posted: Mon Apr 08, 2013 11:46 pm
If you have a WS model, there is no adjustment. If the WS brightness isn't changing when you change the level, the backlight may be malfunctioning.
If you have a 6.5" HS or HX, you can try going to the SET MENU, Display Unit Maintenance, PIC Calibration page and adjusting the Dimmer Minimum Override. There is a limit to how dark it can get that varies with each model and the environment. There may be some room for adjustment in your installation. Allow the screen to warm up first.
If you have an 8.4" or larger screen, the dimmer minimum should already be set at the lowest reliable point. Values 0 and 1 should not be used.
Re: Screen Dimming
Posted: Sun Jun 23, 2013 2:44 am
by dzk2000
I have tweaked this setting before and it worked great, until I disconnected the battery for a day of maintenance. It seems this option is not stored in permanent memory and must be retweaked if you ever remove the efis from power. I love to fly at night, and there is nothing better in an RV8 on a clear starry night than to dim all intruments and enjoy the sky through the bubble canopy.
Re: Screen Dimming
Posted: Mon Jul 01, 2013 8:29 pm
The Dimmer Minimum Override is stored with the other settings in the SET MENU. It should remain set until the settings are wiped or restored.
Re: Screen Dimming
Posted: Mon Aug 19, 2013 6:08 am
by Alon
informative disscussion going on..:)
