EIS backup power
Postby nightflier » Sat May 23, 2020 3:02 am
What is the best way to have two sources of power to the EIS 6000?
nightflier
Re: EIS backup power
Postby GRT_Jeff » Wed Jun 03, 2020 9:19 pm
The simplest solution for continuous power is to use diodes to isolate each power input and combine the outputs. You need diodes that are rated for the voltage and current. Many of our other products do this internally for multiple power inputs. I would have to look up which ones we use. The input with the highest voltage will deliver the power.
Return to Horizon WS/HS
