Newest NAVData update doesn't fit
Posted: Wed Feb 12, 2014 7:23 pm
by 1 Victor Fox
The newest NAVData update doesn't fit on my usb stick (that GRT supplied). It says there is not enough space. GRT: fyi
Re: Newest NAVData update doesn't fit
Posted: Wed Feb 12, 2014 7:42 pm
by 330drvr
I presume that you have deleted files no longer needed on the USB stick. That would free up room.
Posted: Thu Feb 13, 2014 4:19 pm
by 1 Victor Fox
Upon closer look, the update is only 6.7 mb. The original usb stick from GRT is 64 mb so I don't see where there is a problem. I have free'd up plenty of space but I still get the notice for some reason.
Posted: Tue Feb 18, 2014 7:13 am
If some writes to the flash drive didn't finish correctly, the file system can lose track of the free space. If you tell the computer to check the drive for errors and fix them, it should clean that up. Then see if there are any extra files.
On Windows XP, you can right-click on the drive, then Properties, Tools, Check Now to use the built-in repair tool.
