adsb
Posted: Sat Feb 15, 2020 6:29 pm
by bobnoffs
i have a mini and 2 axis a.p. i have a garmin 327 transponder. the mini supplies mode c info to the transponder . will the echo uat/grt from grt work with my set up ? thanks for any info. sometimes straight from the horses mouth is slower.
bob noffs
Re: adsb
Posted: Fri Feb 21, 2020 3:02 am
Yes, this is a common setup. The Safe-Fly + echo package can receive control instructions from the Mini and get altitude from the Mini. The echo will read the squawk code through its Transponder Monitor power circuits when the transponder replies to a radar interrogation. The control interface uses a serial port and the ADS-B IN traffic and weather uses a serial port. The Safe-Fly also has two low-speed serial ports on it if you need to move something.
