Can anyone tell me what the preferred aux connections are for the fuel pressure and amp meter?
Also I can't seem to find what wires go where for CS-01 current sensor....there are 3 wires coming out of it. Is there a page I'm missing? Thanks in advance
EIS preferred aux connections
Re: EIS preferred aux connections
you can use anyone of the 6 aux functions for any extra sensors that you might install. There are no "preferred" choices for the aux layouts. Just make sure that you write down the assignments so that you can do the programming later for EIS and EFIS.
Here is the link for the CS-01 current sensor.
http://grtavionics.com/documents/AMP_HE_RevC.pdf
GRTBen
Tech Support
Tech Support
Thanks. Exactly what I needed!
