hall effect current and blue wire? resistor?
N333M
Post by N333M »
Just want to be clear, the Hall effect requires the blue 4.8 volt excitation wire. Does this wire need a resistor paralleled in the same manner as the fuel senders?
Or do you simply hook up the blue 4.8 v wire from the EIS to the blue wire from the hall effect sensor ring?
thanks
Don
N333M
Don G.
Central Illinois
RV9A 160 hp O-320 carb.
Re: hall effect current and blue wire? resistor?
This sensor does not use a resistor. It is directly connected to the 4.8V wire.
jnewsum1
Post by jnewsum1 »
The Hall Effect sensor blue wire (4.8V) input just gets connected directly to the EIS 4.8V Sensor Excitation Output (pin 25).
N333M
Post by N333M »
Thanks men!
N333M
Don G.
Central Illinois
