hall effect current and blue wire? resistor?
Posted: Thu Mar 01, 2018 1:34 am
by N333M
Just want to be clear, the Hall effect requires the blue 4.8 volt excitation wire. Does this wire need a resistor paralleled in the same manner as the fuel senders?
Or do you simply hook up the blue 4.8 v wire from the EIS to the blue wire from the hall effect sensor ring?
thanks
Don
Re: hall effect current and blue wire? resistor?
Posted: Thu Mar 01, 2018 4:33 am
This sensor does not use a resistor. It is directly connected to the 4.8V wire.
Posted: Thu Mar 01, 2018 4:37 am
by jnewsum1
The Hall Effect sensor blue wire (4.8V) input just gets connected directly to the EIS 4.8V Sensor Excitation Output (pin 25).
Posted: Thu Mar 01, 2018 1:14 pm
by N333M
Thanks men!
