Mini-AP SerialPort 3?
Postby MolsonB » Sat Mar 09, 2019 4:06 am
I noticed in the Mini-AP, there is a 3rd serial port showing up. But can't find any documentation on the pins.?
MolsonB
Re: Mini-AP SerialPort 3?
Postby GRT_Jeff » Sat Mar 09, 2019 5:11 am
It is the recommended port for the magnetometer. It is also a general purpose serial port. This is documented in the Mini-X manual. Pin 9 is Serial Port 3 Output and pin 10 is Serial Port 3 Input.
Postby MolsonB » Sat Mar 09, 2019 7:47 am
GRT_Jeff wrote:It is the recommended port for the magnetometer. It is also a general purpose serial port. This is documented in the Mini-X manual. Pin 9 is Serial Port 3 Output and pin 10 is Serial Port 3 Input.
AH okay. I see the option for Magnetometer connected to Yes. Figured it would 'grey' out Serial Port 3 afterwards.
MolsonB
Return to Mini B/X/AP/GA
