Air/Fuel monitoring
Rob Henderson
Air/Fuel monitoring
Post by Rob Henderson »
Hi all
I would like to connect a Air Fuel O2 Sensor to an analog input.
The sensor outputs 0v-5v for 10-20 a/f.
any suggestions as to where to begin programming?
thanks
Re: Air/Fuel monitoring
To convert 0V-5V to an integer 10-20:
Analog # Function: Aux (EIS compatible)
Analog # Internal Pull-Up: Off
Analog # Scale Factor: 5
Analog # Offset: 20
Analog # Sensing: Forward
Analog # Integer/Decimal: Integer
Analog # Aux Function: Aux
Analog # Aux Name: A/F
Optional:
Analog # Remote Channel: (pick an unused channel 1-16 if you want to send this input to another display)
For one decimal place, multiply the scale factor and offset by 10 and configure it for Decimal mode.
Rob Henderson
Works perfectly
