Landing Gear Voice Alert
Re: Landing Gear Voice Alert
It is functional in the beta versions when you have analog inputs for at least one gear up/down signal. The no-signal reminder-only mode that some people want is not functional. I will attach the current documentation.
- Landing Gear supplement.pdf
- (80.47 KiB) Downloaded 2046 times
Thanks Jeff! This is great! I was able to get it connected and working on one of my DUs, I made a bad assumption that the indication would be shared via interdisplay link, is that something that may come in the future? I'll make additional connections to the other DU for now, but I'm starting to get thin on inputs.
Thanks again for this one, it's a huge safety add!
-John
-John
We intend to send things like this over the display link but we didn't add display link support for it yet.
Beta updates for the 10.1, HXr, HX, and EX are now on the web site.
Fixes warnings incorrectly generated for gear locks that aren't configured.
Fixes warnings on takeoff and improves warning situation during go-arounds.
Sends gear lock inputs over the display link. After configuring inputs and locks on one display, enable "Send Analog Inputs" in the display link settings for that display. When the other displays see the data, the Gear "Locked" input options in the Landing Gear menu will include "Display-Unit Link" as an option. Other gear settings have to be manually configured as desired.
Note these beta updates will suggest Adaptive AHRS 73 and may recommend the current Safe-Fly v4 update on the Power Up (ACCEPT) page. A copy of those updates are included.
