Misc Questions
Posted: Wed Oct 30, 2013 1:47 pm
Investigating another problem the other day, I measured the regulated 12 volt output of my EIS (red/green wire). It measured 10.5 volts when the battery buss (power to EIS) was 12.5. Is this normal? Shouldn't it be close to 12 volts?
I ocassionally see variation in fuel flow which I don't understand. Perhaps that is because the voltage to the transducers is not constant?
An unrelated question. I am using 5 of the 6 aux inputs. The one I'm not using (Aux 5) has SF=0 and OFFSET=0 and Min and Max limits for Aux 5 are set to 0. There is no wire connected to the pin on the connector for that input. Yet when I bring up the Aux 4,5,6 page, 31.4 is displayed for Aux 5. How come?
