Hi all
I would like to connect a Air Fuel O2 Sensor to an analog input.
The sensor outputs 0v-5v for 10-20 a/f.
any suggestions as to where to begin programming?
thanks
Air/Fuel monitoring
Re: Air/Fuel monitoring
To convert 0V-5V to an integer 10-20:
Analog # Function: Aux (EIS compatible)
Analog # Internal Pull-Up: Off
Analog # Scale Factor: 5
Analog # Offset: 20
Analog # Sensing: Forward
Analog # Integer/Decimal: Integer
Analog # Aux Function: Aux
Analog # Aux Name: A/F
Optional:
Analog # Remote Channel: (pick an unused channel 1-16 if you want to send this input to another display)
For one decimal place, multiply the scale factor and offset by 10 and configure it for Decimal mode.
Analog # Offset: 20
Optional:
Rob Henderson
Works perfectly
