ADHRS
Posted: Thu Nov 21, 2019 6:34 pm
Reading the manual, if I have two Sport EX displays, both have an adaptive AHRS inside. If I’m using one as PFD and the other as MFD, and the PFD AHRS should fail, it should be the case that the MFD AHRS takes over. Does this require a dedicated serial port on each display or does interdisplay serial connection serve this function? I’m trying to determine how many serial ports are needed.
