Sport sx not showing engine info
Posted: Fri Oct 02, 2015 11:52 pm
by marvk
Not getting tach, oil temp and pressure or cylinder head temp on the EFIS. Bar graph and gauges show but don't work. Readings on EIS show. Can't figure out what I missed in the set up. Also wondering if 2 of the 4 coolant temp can be removed from the EIS settings.
Re: Sport sx not showing engine info
Posted: Sun Oct 04, 2015 1:19 am
by jclark
What version of software do you have on the SX?
The engine stuff has been working just fine for a long time now.
Data should display even if it "looks" wrong. In the engine page setup and "limits" page you can set how various data elements are shown.
Posted: Thu Oct 08, 2015 11:37 am
by JimB
On the first set up page (General Setup), is the counter for EIS changing? This will confirm that the data is getting to the EFIS.
If not, check the wiring between the EIS and EFIS and the baud rate (should be 9600).
Posted: Thu Oct 08, 2015 5:21 pm
by marvk
Serial number 2 was not configured for EIS input, once I did this the gauges read.
