Oil Pressure
n747jg
Oil Pressure
Post by n747jg »
I noticed my oil pressure indicates 12 PSI when static, engine not running. I'm guessing my oil pressure indication with the engine running is probably indicating the same 12 PSI too high. Can it be adjust it to zero?
yatesg
Re: Oil Pressure
Post by yatesg »
n747jg wrote:I noticed my oil pressure indicates 12 PSI when static, engine not running. I'm guessing my oil pressure indication with the engine running is probably indicating the same 12 PSI too high. Can it be adjust it to zero?
HI,
have noticed same...all these yrs later, howd you get on?
Rgds
VELOCITY-XLRG
Re: Oil Pressure
Post by VELOCITY-XLRG »
Hi, has anyone figured this one out, I have the same on new install Remote EIS and HXr's...
