Engine Bar Graph
Walter Casey
Re: Engine Bar Graph
Post by Walter Casey »
Thank you Bob Turner,
Please share with us how to save all our settings to a memory stick?
Best wishes,
Walter
Walter (Mike) Casey - You can download a rewritten EFIS Pilots Guide at http://www.caseyspm.com/RV7A.html
Backing up user settings is described on page 7-1 of the Set Up Guide. Go into the set up menus, select Display Unit Maintenance, select back up settings.
Walter Casey
As I said earlier I was wrong, you can indeed dump the data to a memory stick.
A sample of what you get is shown on the left, what I would like is a listing with item numbers as shown on the right:
