I currently have an HXr system with a GTN650 and looking at my ADSB options including the Garmin GDL88.
I am assuming the HXr system doesn't communicate directly with the Garmin GDL88, however, if its connected to the GTN650 can the GTN650 then feed traffic and weather to the HXr?
Nikolaos
GTN650 & GDL88 into HXr
Re: GTN650 & GDL88 into HXr
Nikolaos
You are correct that the GDL 88 does not communicate directly with the HXr. Unfortunately the information from the GDL 88 does not come through the GTN650 into the EFIS either. There is currently no way for us to read the information coming out of the GDL 88 for use in the EFIS systems.
GRTBen
Tech Support
Tech Support
