Oil Temp Not Working
Posted: Sat Jul 06, 2013 11:52 pm
I ran my engine for the first time and discovered that the Oil Temp was not working on the EIS or HX EFIS's. Here is what I have done thus far in an attempt to figure out the problem.
1. I have verified that there is continuity from EIS D-sub connector Pin 15 to the Oil Temp Sensor.
2. I have a good ground on the other wire on the Oil Temp Sensor
3. I removed the Oil Temp Sensor and measured the resistance across the two Sensor Wires as I heated the probe with a heat gun. Resistance decreased rapidly so it appeared to be working.
Any other ideas I can try?
