EGT on far left upper number reading low
Posted: Wed Aug 14, 2013 4:59 pm
by Gardenguy
My EGT sensor on the far upper left number (200 -300 degrees)is reading low on my EIS system. question: what cylinder is it and what might be the cause? Also what type of oil pressure sensor do I need for a Jabiru 3300 engine?
Re: EGT on far left upper number reading low
Posted: Tue Aug 20, 2013 1:03 pm
by GRTBen
The EGTs on an EIS 6000 are arranged out like this
cyl 1 cyl 2 cyl 3
cyl 4 cyl 5 cyl 6
This is the way the inputs are arranged. Not necessarily the way that they are wired to the engine. You can use a heat gun to check the arrangement of the cylinders on the eis to make sure they are layed out to match the engine,
