SkyGuardTxw
Nikolaos
SkyGuardTxw
Post by Nikolaos »
Looks like SkyGuardWX by Levil Technologies is the low cost ADSB transceiver in the market right now. Is there any work being done to make it compatible with the GRT systems?
katieb
Re: SkyGuardTxw
Post by katieb »
The SkyGuard Vision Pro (not done by Levil, but it works with Levil's AHRS) can't work with GRT because it does not have USB or serial data transmission capability and our EFIS systems do not receive Wi-Fi.
Katie Bosman
Pilot/Tech Writer
Jabiru USA Sport Aircraft
http://www.usjabiru.com
GRT Pilot Since 2008
Nikolaos
Re: SkyGuardTxw
Post by Nikolaos »
Thanks.
Roger
Re: SkyGuardTxw
Post by Roger »
I have been told that the new SkyguardTWX is now compatable with the GRT EFIS. Does anyone have other information?
Re: SkyGuardTxw
Several customers are using the SkyguardTWX with our systems. They have a serial output now. When you order it you have to get them to change the baud rate to 230400 or 115200 to be compatible with our serial ports.
