Skyradar D2...
Posted: Tue Oct 15, 2013 1:47 pm
by n468ac
Are you going to add the TFR's to the MAP page from the Skyradar D2 ADS-B?
Re: Skyradar D2...
Posted: Fri Oct 18, 2013 3:10 pm
by kwiatkma
Ditto. I'll second that.
Re: Skyradar D2...
Posted: Sat Oct 26, 2013 1:23 am
Yes, we are going to add more of the ADS-B weather data, including TFR's. I'm not sure when that will be in the software. I will try to post here when I know more.
Re: Skyradar D2...
Posted: Tue Nov 12, 2013 12:32 am
by Bavafa
TFR would be really great, high on my list to see.
Re: Skyradar D2...
Posted: Wed Apr 05, 2017 11:12 pm
by mamcelr
This thread is old and I found a second one referring to the same request to show TFR information on the DU. What I don't see is a response that it has been added. I have an HX and I use Seattle Avionics Charts in Map mode along with a SkyRadar DX. I do not get TFR information on the HX, but it does appear on my iPad within FlyQ.
Has this been resolved or do I possibly have a bad setting?
Re: Skyradar D2...
Posted: Fri Apr 07, 2017 3:44 am
ADS-B TFR's were added to the HX software in October 2014 (and all models except WS/HS). The TFR outlines are displayed when airspaces are displayed, which is controlled by the "Max map range: airspaces" setting in SET MENU, Moving Map.
Re: Skyradar D2...
Posted: Fri Apr 07, 2017 5:23 am
by mamcelr
Thank you Jeff. I must have a bad setting and will check. I've only had the plane for a year now and I'm still learning everything. Will the outlines show when using Seattle Avionics charts?
Re: Skyradar D2...
Posted: Wed Apr 12, 2017 3:07 am
TFR's are drawn on top of the charts. Airspaces are also drawn if the EFIS is warning you about it.
