Backup Battery Voltage
Posted: Mon Jul 31, 2017 3:59 pm
by Bayou Bert
I have the new TCW backup battery, the new 6 amp model, they don't make the 4 amp model I currently have in place.
It is toast.
The new one has a line for reading the voltage of the backup battery.
How do I get that to the EFIS and display it all the time. I have the HXr and the EIS 4000.
Bert
Re: Backup Battery Voltage
Posted: Wed Aug 02, 2017 3:34 am
You can configure one of the 8 analog inputs on the HXr to read a voltage:
Analog # Scale Factor: 25
Analog # Offset: 0
Analog # Sensing: Forward
Analog # Aux Function: Aux
Analog # Aux Name: (Give this input a name for alarms and bar graphs)
Optional:
Then you can configure a data box or bar graph to show this input by selecting the Aux Name you entered. You can also check the voltage in SET MENU, Display Unit Maintenance, Analog Inputs.
The analog inputs are on pins B-14 through B-21 in reverse order. Analog Input 1 is on pin B-21. Analog Input 8 is on pin B-14.
Posted: Wed Aug 02, 2017 12:30 pm
by Bayou Bert
Thanks Jeff, sure appreciate the help.
Bert
Amp Draw
Posted: Wed Aug 02, 2017 12:37 pm
by Bayou Bert
Jeff, if I could get just a bit more info.
What does the 10" HXr draw in amps when up and running?
What does the AHRS draw in amps when up and running?
Reason, I have the HXr and #1 AHRS on the backup battery buss.
With the new battery I am considering adding my second comm to the buss.
Bert
Posted: Thu Aug 03, 2017 1:21 am
The 10.4" HXr can use 2.5A at 12.0V at full brightness and full load.
The AHRS uses up to 0.2A normally, max 0.5A.
Posted: Thu Sep 28, 2017 3:07 am
by MolsonB
Using VPX for amps, not an actual dmm.
Just on a screen, not full load.
HXR + AHRS
Dim 1.1A - 1.0A
Full 2.1A - 2.0A
Posted: Fri Oct 13, 2017 2:13 am
by bd4c
Jeff,
There is a warning analog out on the IBBS as well - spec:
The IBBS unit has a low voltage warning output, pin 3. This pin may be used to drive an LED indicator or to provide a digital signal to indicate the main input bus is in a low voltage condition. When the main input bus (connected to pin 5) falls below about 11 volts this output will drive to a low state. Maximum current sourced on this pin is 25 milliamps.
What would we change to the analog settings to accommodate the above? Same settings, or a different scale factor?
Posted: Fri Oct 13, 2017 3:28 am
bd4c wrote:There is a warning analog out on the IBBS as well - spec:
It sounds like this warning output does not provide the high voltage so you need a pull-up somewhere in the circuit. The settings would be the same except you would need to set the Internal Pull-Up to On. The exact value you get will not be important. If you use the internal pull-up, which is 10-12V, you could consider more than 5 volts as good and less than 5 volts the "low voltage warning" state. Set the Min alarm limit to somewhere between 2.0 and 5.0. The high voltage could vary depending on the circuit but the voltage should drop all the way to zero in the low state.
**FOLLOW UP QUESTION** Re: Backup Battery Voltage
Posted: Sun Sep 14, 2025 8:46 pm
by VELOCITY-XLRG
Good Afternoon Jeff,
I was hooking up my TCW Battery Voltage indicating wires to the Analog inputs as you described below (years ago!) and they worked PERFECTLY!
I have a question regarding where you state that you can send this input to another display (I assume this means it can then show on both displays?) as follows:
"Optional:
Analog # Remote Channel: (pick an unused channel 1-16 if you want to send this input to another display)"
When I tried this, I said to send to channel 1 (no idea what that means) and then saved it and tried to view it thru the Set Menu and it does not show any data.
Can you assist?
Gary E
VELOCITY XLRG
ARB
\Re: Backup Battery Voltage
Post by GRT_Jeff ยป Wed Aug 02, 2017 3:34 am
Analog # Offset: 0
Optional:
Posted: Tue Sep 16, 2025 6:10 am
You can't view it in the SET MENU. The other displays will detect that a remote channel is available as an option for a bar graph or data box. You have to go to a bar graph or data box setting on the other displays and set it to the remote channel. The remote channel number is just a unique number that you pick that must not be used by any other remote channel setting on any display, since all displays on the link share the same set of remote channels.
