HPS-SS-01 Fuel Pressure Sender Install
Airdog
Post by Airdog »
Since the HPS-SS-01 comes with 3 wires and a bare shield in a black sheathing, just wanted to confirm that it's ok to cut the wires and bare shield shorter?
I'm building a pusher aircraft so the fuel pressure sender will be just on the other side of the firewall from the EIS4000 unit and I don't need the length of cabling that came attached to the HPS-SS-01.
Re: HPS-SS-01 Fuel Pressure Sender Install
They're normal wires. The calibrated part and everything important is inside the main sensor body. You may find another wire or two inside the black sheathing. Just leave them unconnected.
Airdog
Post by Airdog »
Great! Thanks Jeff.
