Carb heat warning
Posted: Fri May 18, 2018 9:19 pm
by TONYBISHOP
My twin HXr is now working well. But one outstanding glitch. I have a carb temperature sensor, which produces sensible readings. I've set limits for it; I've tied several settings including 0 to 100 and 1 to 80. But it always shows an alarm, despite it being well within bounds. Is this a software problem, or am I doing something stupid?
Re: Carb heat warning
Posted: Sat May 19, 2018 2:02 am
The Carb Temp alarm works differently. It goes off when you're between the limits instead of outside of them. It is meant to be set to a range that warns you about carb icing.
Posted: Sat May 19, 2018 9:58 am
by TONYBISHOP
Aaaaah! Many thanks Jeff.
