Loading new software
STEVEC
Post by STEVEC »
Hi
I have just attempted to do an update the software on my Mini X. I was unable to find any Load options under the AHRS Maintenance menu. Have they been moved elsewhere. I made the obvious error and allowed the MiniUp-2.dat file to remain so have renamed that and will do the update next hanger visit.
My software levels at the moment are
Display 4.03
AHRS 61
Battery and Air Data levels I can't find anywhere.
Any help would be much appreciated
Rgds Steve
Re: Loading new software
The Load AHRS Software function has not been moved. It is still in AHRS Maintenance near the end, before the Air Data (AD) lines. The Air Data version and update function is also there at the end but it's unlikely you need to update it. There haven't been any air data updates in a few years. The Battery version and update is in SET MENU, Display Unit Maintenance, Battery Status. If you see Battery software version 5 an update is recommended.
STEVEC
Post by STEVEC »
Thanks I will look a bit harder
Steve
STEVEC
Post by STEVEC »
Hi
I have solved the mystery of the missing menu options. I have found that if I turn the selector knob slowly the menu stops at the magnetometer options but if I turn it rapidly more options appear. Found what I needed and all updates complete.
Steve
