Reset to new, Mini GA
Posted: Sat Feb 04, 2023 6:38 pm
by MiniGA
Bought a used GA and was hooked to magnetometer and engine parameters, I am not using either of those, strait gps antenna thats it, how do I clear the
revious owners settings?
Re: Reset to new, Mini GA
Posted: Mon Feb 06, 2023 11:49 pm
by MiniGA
It should reset back to original when you update the AHRS and Display software.
Posted: Tue Feb 07, 2023 6:54 am
What??? That suggestion is insane! We wouldn't want to wipe out everyone's settings every time they load an update. Updates maintain previous settings on purpose.
If you want to turn off the magnetometer input, you can go to SET MENU, General Setup, and turn off the Serial Port Input and Output that's configured for Magnetometer, and set the "Magnetometer Connected" to No or Auto.
You can turn off engine functions by changing SET MENU, Display Unit Maintenance, ENG Option to No.
If you want to reset ALL of the Mini settings back to factory defaults, you can go to SET MENU, Display Unit Maintenance, scroll down to "Reset/Clear Settings", push the knob to alter it, rotate the knob clockwise about 15 clicks, then keep going until it says "Everything", then push SAVE and wait about 10 seconds for it to reboot itself. The defaults turn the engine functions on so you will need to change ENG Option to No after it reboots.
