Cannot figure out how to change altimeter setting
Posted: Mon Feb 06, 2023 12:03 am
by MiniGA
Manuel says from PFD page turn the knob, that changes my heading bug. Its a GA and reads GPS altutude or MSL I believe is what GPS altitude is, I would like to clear the big altimeter setting off the Mini GA screen altogether since we indicate MSL all the time, but I dont think you can clear it so I would like it to say 29.92 instead of 29.50 it is stuck on.
Re: Cannot figure out how to change altimeter setting
Posted: Mon Feb 06, 2023 11:51 pm
by MiniGA
When you update the Display software it will reset
Posted: Tue Feb 07, 2023 7:05 am
It sounds like this Mini had a remote Air Data module connected. If that's not the case anymore you can go to SET MENU, General Setup, and look for a Serial Port Input configured for "GRT Air Data Module" and change that input to Off. Or you can reset all the settings as in the other post. If it has a remote air data module then you would rotate or push and rotate the knob on the PFD page to change the baroset.
