Software Updates
Posted: Fri Jun 02, 2023 2:45 am
Hi Jeff:
Im in the process of updating my HXr from sofrware 7 to version 8.
I have done this in the past with previous versions. However, i have not been able To make it happen again. Here is what i have been doing:
I format a usb drive in a windows pc with fat32
I download the update and save it directly on the root directory, only the DAT file.
I inserted the usb directly in the back of the screen while it is OFF.
Power up the unit, and go to menu, display maintenance.
Check everything working and the status of the USB port.
Select load efis software, select yes for are you sure.
A message comes out that the DAT file is not located.
Tried it several times and different ports.
Any other suggestions of what can be going on over here?
Alternate format for formatting the USB drive!??
Thanks in advance!
Afif Saybe
LongEZ HRATQ
Thanks in advance!
Afif Saybe
LongEZ HRATQ
