Tach Time vs. hourmeter
Posted: Wed Sep 27, 2023 3:30 pm
Since purchasing my RV-7A with an EIS-4000, the tach time aggeregation has been virtually the same as Hobbs time. That is, tach time always matches Hobbs time. RPM displays consistently and correctly. My understanding is that tach time should be a function of RPM. The Hourmeter seems to run above a certain RPM, which seems close to, but not really tach time. Is there a way to configure tach time to be more(?) sensitive to RPM??
Have EIS4000 connected to XP-IO-360-B1EC3. All engine monitoring sensors are working properly. Have a SureFly SIM4P on the left and Slick Mag on the right. SureFly is currently set without electronic advance to better match spark plug firing on the Slick.
Thanks in advance for any response.
