Tachometer input from SureFly SIMs
Posted: Mon Apr 07, 2025 11:13 pm
Does the EIS require SureFly's Tach2 product for tachometer input?
Here is the description of the product:
Tachometer Signal Converter
The Tach Signal Converter (Tach2) converts SIM P-Lead signals to negative –going signals compatible with the Horizon P-1000 digital tachometer input and to a positive-going 0-5V square wave signal compatible with electronic tachometers that rely on a signal from a magnetic pickup inserted into a magneto.
I'm assuming that it is required and that the positive going 0-5volt square wave signal is what will work best.
