RPM sensor
Posted: Fri Jun 13, 2014 8:16 pm
I current have a Westach 720-14R Hall Effect sensor for the second RPM connected to a standard Slick mag. I did a test with a multi-meter, and it seems
that the sensor only varies between 0 and 0.5 volts when I slowly turn the prop.
In the EIS setup, I set the second RPM input to sensitive , but it still does not detect the RPM.
Two questions, is there some other settings in the EIS to get this to work?
If not, is there a recommendation for an easy installation to get RPM into the second RPM port.
Just for info, the primary RPM is connected to an electronic ignition, and that works fine.
