Mini wiring questions
DuckDriver
Post by DuckDriver »
The OAT sensor has 2 white wires coming out of it but only one is listed as going to pin 15 on the DB25. Where does the other wire go?
If I want to use my TRIG 22 with the control head do I just connect the one wire to the Mini so I can see the squawk code on it?
Re: Mini wiring questions
There are instructions for the temperature probes in the on-line documents, including placement suggestions. One wire goes to ground.
DuckDriver
Thanks for that. Got another one. What do I set the serial port to so the Mini's internal GPS talks to my Dynon D10A?
If you're using a Trig control head with the TT22, then you can't send any of its information to the Mini.
To send GPS data out of the Mini, use the "Autopilot (NMEA0183)" output. This output acts like a NMEA0183 GPS and includes position data from the currently selected GPS.
