Sectional Chart (Seattle) View
Posted: Mon Aug 11, 2014 4:07 pm
by gdtrfb58
I successfully downloaded the Seattle charts and the GRT loaded them on start up (First try was using a PNY USB Stick which would not work, even after FAT 32 re-formatting. Works fine with Sandisk out of the box.)
When I go to Map view and select "Chart" and choose "Sectional", I see the Sectional (Great display!) but I lost both Insets. The softkey to configure each Inset is still visible but no Inset is present and pressing the key does nothing.
Also, is there a split screen option for PFD/Map? I don't see it on any screen.[/list]
Looking forward to a new system version where Sectional can be the background with weather overlay.
Re: Sectional Chart (Seattle) View
Posted: Mon Aug 18, 2014 5:02 pm
by Widget
You should be able to still have the MAP with the INSET boxes. Are you saying you have them until you select CHARTS on MAP options? If they are showing on other MAP pages they should show with the CHARTS selected.
Also, as to the split screen, whatever MAP you are viewing using MAP OPTIONS will display on the SPLIT, or any other MAP page. To get to the SPLIT screen, go to SCREEN, PFD OPTIONS, SPLIT and you will get the screen below.
You can make this the default screen in the SETUP menu.
Holler if you have any questions..
Posted: Mon Aug 18, 2014 7:50 pm
by gdtrfb58
exactly! I have the insets on all Map screens, but when I switch to "charts" the insets disappear. The softkeys for inset are visible, but pressing them does nothing.
Posted: Tue Aug 19, 2014 7:59 am
When you switch to charts, are you also switching to NORTH UP? The insets aren't currently displayed on the north up view because they block so much of the screen, and on the north-up view you could be heading toward the inset box.
Posted: Thu Aug 21, 2014 10:23 am
by gdtrfb58
That's it! Thanks.
