Best ADSB Receiver Only?
Posted: Sat Sep 06, 2014 4:50 pm
by Sparky
Looking to replace the Expensive XM sat subscription and remove the WxWork USB receiver...
Running dual HX screens and the trig T22...
Any suggestions ?
Can you directly plug the SkyRadar D2 where the WxWorx was or does it need a hub?
Re: Best ADSB Receiver Only?
Posted: Sat Sep 06, 2014 4:56 pm
We are clearly typing at the same time! The Skyradar USB plugs into the back of the HX.
The Skyradar does need to be wired to 12 volt power.
Posted: Wed Oct 22, 2014 10:29 pm
by 1 Victor Fox
With the Skyradar, can you remote mount it? If so what do you do with the antennas? :?:
Posted: Thu Oct 23, 2014 1:01 am
I have an RV-10 which has a fiberglass cabin top. I remote mounted the Skyradar; glued the antennas to the inside of the fiberglass door posts (one on each side); connected the antennas to the Skyradar with some 52 ohm coax with SMA connectors (one male, one female) that I bought off NewEgg.com for about $7. Works great.
Skyradar does sell some remote mount antennas with a suction cup, to mount on a window, but I get lots of stations with the set up described above, which use the stock antennas.
