N325MB, Vans RV9A made it's first flight today.  Friend, made the first flight.
Panel is HXr on left and HX on the right.  At some point in the flight
a yellow "altitude" popped up on the HX above and to the left on the HX set on
the engine page.  I can't find the meaning in documents.
The HXr had a yellow Alt in the upper left of the screen too.
Can someone please tell me what this is telling me.
I have the EIS4000 monitor.
John Bertucci
						Yellow Altitude
Re: Yellow Altitude
You can set a target altitude on the main pfd page, and then you'll get a warning if you deviate by more than 200 or 300'. You must have enabled the alarm in the set up process.
						Re: Yellow Altitude
Also, If you have audible warnings enabled and wired in you should have heard "altitude" through your headset.
							Jerry "Widget" Morris
				Bayou Bert
Re: Yellow Altitude
Late getting back.  That's what it was.  Sure appreciate the info and help.
Trying to get a grip on a procedure to check out everything before flying.
Sure is a lot of bells and whistles for an old Cessna driver.
Thanks again
Bert
Thanks again
Bert
