Fuel Qty reading Dial indicator Wrong.
Posted: Thu Mar 21, 2013 12:39 pm
I have finally gotten my capacitive sensors working and now have odd dial readings. The numbers are correct, but you can see from the picture that the dial needles do not represent the number.
Dial #3 set between 1 and 20. changing these numbers does not change anything on the dial at all. Left tank # is 0 which is accurate but needle not at zero. Right tank 9 also accurate but needle at full.
Any idea what this might be?
