Voltage Readings
Sportsman
Re: Voltage Readings
Post by Sportsman »
Hmmm... That's exactly what I have done, Jeff. I probed with mcro-probes inserted into the back side of the d-sub connector pins and measured a voltage that's pretty darned close to one diode drop higher than the voltage reported by the EFIS. I only have two buses supplying power so have only done this on two of the three inputs. Each of those two inputs shows a consistent 0.6VDC higher than EFIS-reported voltage.
Heaven help me if I'm dropping 0.6V across a DB25 connector...
Post by Bobturner »
I wonder what sort of internal failure could cause this? My HX reads the buss voltage within round off error (0.1 volt). IIRC I used 18 gauge wire for power and ground.
It sounds like the calibration is bad. The power input voltages are measured before the diodes and the board has a calibration probe point there on input 1. I don't think it could be any hardware failure, although I have seen one board where the ADC was inconsistent from one boot to the next (bad self-calibration during power on I suspect).
Sportsman
Post by Sportsman »
Interesting... Today I was again playing with our instrument panel and the HX was showing a voltage input value much closer to what I was reading - within a tenth or two of a volt. This is quite different from what I had previously seen. Jeff's suggestion of varying display brightness to see if reported voltage tracks changes in input current demand is a good one and in our case I was able to see some correlation between reported input voltage and brightness. Higher brightness settings consume more current, thus there is greater voltage drop across wiring etc, and a lower input voltage reported.
I'll monitor to see if the reported voltage changes after power-cycling the HX.
psychose
Post by psychose »
hello folks,
Sorry about the long delay, but I finally was able to measure voltage difference on EIS vs Battery, with and without engine running.
engine running: batt voltage: 14.5 v, EIS indication: 14.1 diff=.4 volts
engine not running: batt voltage : 12.5 v, EIS indication: 11.8 diff=.7 volts though this difference can vary +/- .1 volts.
A type of bias function, even if accurate only within a certain current range, would be nice, or some other way to get a more accurate measurement.
For now I will account for the difference in my EFIS alarm settings.
Normand
C-GNGN
psychose
Post by psychose »
Hello Folks,
Many moons later, I finally got around to adding the 240 ohm resistor from the battery bus to the EFIS.
I now get an EFIS voltage reading within +/- 0.01 of the battery voltage, so I'm very satisfied. Thanks to Jeff DeFouw for his support.
To convert an analog input into a voltage with tenths:
Analog # Scale Factor: 25
Analog # Offset: 0
Analog # Sensing: Forward
Analog # Aux Function: Aux
Analog # Aux Name: Batt Bus (Give this input a name for alarms and bar graphs)
Optional:
After this is configured, the aux name ("Batt Bus" for example) will be an option on bar graphs and data boxes.
Normand
RV8 C-GNGN
BillinDurham
Post by BillinDurham »
I assume this is still valid. Having had the same set of problems with accurate voltage displays, I'm intend to configure 2 analog inputs as described below to display bus voltages on my 2 bus, 2 batt, 2 alternator Z-14 system.
Confirmations or comments welcome. Thanks.
psychose wrote:Many moons later, I finally got around to adding the 240 ohm resistor from the battery bus to the EFIS.
Analog # Offset: 0
Optional:
Normand
RV8 C-GNGN
Bill Watson
8NC8 Durham, NC
RV10 HX, G430w, NavWorx, EIS
