Hi I just finished my Anual and did a pitot static test to my configuration.
No leaks and everything checked AOK, just for a difference of 20ft in the altimeter test.
Knowing its in acceptable range, can we adjust this error in the settings???
AFIF SAYBE
LONG EZ HR-ATQ
Altude adjustment
- saybeengineering
Altude adjustment
Afif Saybe
LongEZ, HR-ATQ
LongEZ, HR-ATQ
Re: Altude adjustment
Altimeter Calibration is described in the HXr User Manual in the Altimeter Calibration section. You can calibrate with just the field elevation and altimeter pressure setting (Partial) or from zero all the way up to your plane's maximum using a test set (Full).
HXr Documentation: https://grtavionics.com/product/horizon-hxr-efis/
- saybeengineering
Thanks Jeff.....Altitude has been corrected with the BIAS...
Regards,
AFIF SAYBE
LongEZ HR-ATQ
Regards,
AFIF SAYBE
LongEZ HR-ATQ
Afif Saybe
LongEZ, HR-ATQ
LongEZ, HR-ATQ
