GTN 650/750 Firmware Upgrade
jpfli
Contact:
Post by jpfli »
For those of us with GTN navigators is upgrading the firmware worthwhile?
Will the VNAV ver 6.50 firmware VNAV capabilities be able to be sent to and seen by the HXr?
Regards,
John
Re: GTN 650/750 Firmware Upgrade
You’ll need GRT to give you a definitive answer, but probably not. The GTN VNAV data is being sent out using a new arinc format (Garmin429 instead of gamma1) that most Garmin products cannot read either.
jpfli
Contact:
Post by jpfli »
Bobturner wrote:You’ll need GRT to give you a definitive answer, but probably not. The GTN VNAV data is being sent out using a new arinc format (Garmin429 instead of gamma1) that most Garmin products cannot read either.
Thanks Bob!
I'll wait for Jeff's response on both the above, and the next question below:
Since v6.5 gives the 650 a more user friendly interface, do you know if the 650 firmware upgrade will cause any loss of functions that are currently available and flow from the 650 to the HXr?
I don’t know, but certainly you have cause to be concerned. This has happened in the past, where some connected equipment no longer worked after a Garmin ‘upgrade’. I’d ask Jeff before proceeding.
I don't know anything about this upgrade. Garmin doesn't tell us anything and I haven't heard anything about it.
jpfli
Contact:
Post by jpfli »
GRT_Jeff wrote:I don't know anything about this upgrade. Garmin doesn't tell us anything and I haven't heard anything about it.
Here is the link to the GTN 650 update:
https://www8.garmin.com/support/collect ... 0-00G3X-00
Info is the 6th bullet point under the additional software heading
I sent you an email with the .pdf
The service bulletin says the new VNAV features work with other Garmin equipment and does not describe how they are sent. That probably means they are in the Garmin proprietary formats. We could look at the data from a DEMO file to see if there are any changes to the standard data streams but I doubt it.
The bulletin does not say the update affects any other equipment, which means current functions are expected to still work with the EFIS and any other equipment.
jpfli
Contact:
Re: GTN 650/750 Firmware 6.50 Upgrade
Post by jpfli »
Has anyone done the 6.50 upgrade?
Any negative results?
Regards,
John
RV-HXr
Post by RV-HXr »
jpfli wrote:Has anyone done the 6.50 upgrade?
Regards,
John
I updated to v6.50. The 650 and HXr continue to cooperate just as before.
Widget
Post by Widget »
I did the upgrade with no negative effects. It did set the VNAV to the Garmin default, which meant that I could not enter crossing restrictions as I had in the past. I went into the SETUP menu and switched it back to how it was before. The new keyboard is nice.
Jerry "Widget" Morris
