Trying to think ahead for a possible Mini-X installation.
How close can you mount two magnetometers? Can they be mounted side by side, or on top of each other, or is there a minimum distance between magnetometer units?
-Dj
Magnetometers
Re: Magnetometers
Magnetometers can be mounted on top of each other or side by side-- they won't mess with each other.
Katie Bosman
Pilot/Tech Writer
Jabiru USA Sport Aircraft
http://www.usjabiru.com
GRT Pilot Since 2008
Pilot/Tech Writer
Re: Magnetometers
Can an HX and a Mini-X share the same magnetometer, or do I have to install one for each?
-Dj
-Dj
Re: Magnetometers
You'll need one for each. The Mini magnetometer has different wiring and different hardware, but it uses the same case.
Katie Bosman
Pilot/Tech Writer
Pilot/Tech Writer
sleddriver
Re: Magnetometers
I would like to mount my magnetometer in the wing tip. My wings are removable. Can I install a 4 pin Molex connector at the wing junction without interfering with the signal of the magnetometer?
Re: Magnetometers
You can add your own connector to the Mini remote magnetometer. A good quality connection with gold plated contacts is recommended for its corrosion resistance.
The magnetometer is documented in the Mini-X and Mini-AP wiring and connector definitions on the Mini Documentations webpage. The 9 pin D-Sub is included by stating which wire goes to which pin on the magnetometer plug.
-Marc Robertson
-Marc Robertson
