Well I finally managed to get a 12.1" display and smaller Hx display installed.  I have a TRIG 22 that is controlled by the HXr.  I have a Pathfinder ADS feeding in as well.  Everything seems to be talking to everything else.  Weather display is almost the same as the 396 I removed.  Looks great!
A 430W and SL40 are installed but not tied to the GRT, controlled by a PMA 8000 audio panel.
I haven't been able to figure out how to remove the "Nav" control boxes in the upper right corner of the HXr display.  I got the "COM" boxes out and the TRIG 22 control display looks like I want it to.  I've been thru the SETUP menu without success.  Can anyone help me out with this?
						HXr Display "NAV' control boxes
Re: HXr Display "NAV' control boxes
"NAV" boxes would appear if you have a serial port configured for an SL30 or have SL30 link settings enabled (in General Setup, Inter-Display Link).
				Jkoonce128
Thanks, that fixed it.  I hadn't selected SL 30 but I was sending commands on the inter display link.  Looks perfect!!
John Koonce
N78MU
						John Koonce
N78MU
