Garmin GTX327 from Mini
Sonex1517
Contact:
Post by Sonex1517 »
Is the Mini encoder output compatible with a Garmin GTX 327?
Robbie Culver
Sonex 1517
N1517S
First flight 10/10/2015
Re: Garmin GTX327 from Mini
Post by Bobturner »
I do not know for a fact, but certainly the Horizon (Hx, HS) encoders are compatible (serial) with the 327 because that is what I have. I'd be very surprised if the mini's encoder software was any different.
Sonex1517
Contact:
Post by Sonex1517 »
A quick email to GRT tech support confirmed it. I am just posting it here for others that have questions
>>Yes, Use an open serial port out and configure it for Fuel Air Data Z format, 9600 baud<<
What settings did you use on the GTX 327 to receive the data?
Robbie Culver
Sonex 1517
N1517S
Post by Bobturner »
set the 327 input to "FADC w/ ALT", same baud rate (9600). Exactly per the installation manual pg 9-23.
To save a port on the HX, I used a 327 serial output to send this data on to the Garmin 420W.
Sonex1517
Contact:
Post by Sonex1517 »
Robbie Culver
Sonex 1517
N1517S
Sonex1517
Contact:
Post by Sonex1517 »
Long overdue update - I have had my GRT Mini successfully connected to my used Garmin GTX327 for over six months.
Installing the interface was easy and quick. Great combination!
Robbie Culver
Sonex 1517
N1517S
