I have the single screen HX System and am using a Garmin 430W as gps#1. When leaving my airport TA50, I put in KLRU direct in the Garmin 430. On climb out I turn on the GRT Auto Pilot, dial in 7500' push the button for Heading/Alt (heading is usually 030 degrees), while climbing out and before the a/p captures 7500', I set up the approach for rwy 30 gps approach for KLRU -Vectors. I then reset the GRT AP (enav, gpv, auto) for the approach to rwy 30 klru, the auto pilot will intercept the runway heading @ 45 degrees (@ this point I press the Execute button on the HX) and the HX will fly a perfect approach to the end of runway 30 @ KLRU! When reaching DA (4800/5000') I press the "Missed" button on the screen of the HX, and the OBS button on the 430 to sequence FIPAK, upon reaching FIPAK, the ap turns the RV6 left to Coses intersection. The 430 shows a holding pattern @ Coses with a tear drop entry, but the HX only shows triangle @ Coses intersection. If I let the a/p fly the plane, when I reach Coses intersection, the a/p will quit flying the plane! My question is "why doesn't the HX Efis show the holding pattern as depicted on the 430 screen"? What am I missing in the set up for the Missed Approach?
LLoyd
