hello everybody! I have been experiencing wrong values of rpm on my eis that are aproximately half the real rpm's. Last saturday, rpm readout finally droped to cero value all together; I have checked setup for engine rotax cdi has not changed (6), it's still there.
Any ideas where I should start checking? Thanks!
EIS 2000 rpm died
NickHospodar
Re: EIS 2000 rpm died
Have you done anything to make sure that the output of the ignition system is working? I haven't seen a tach input just stop working, unless there is some kind of wiring or device failure.
