NavWorx ADS-B Setup with Hx
bdtopp
Post by bdtopp »
I have a NavWorx ADS-B and a dual display Hx system. The NavWorx RS232 Display Serial Data Input (Pin 24), and, the RS232 Display Serial Data Output (Pin 5) are connected to display unit #1 Serial 7 In and Serial 7 Out. When I am in the General Setup for Display Unit #1, what baud rate and value should I use when configuring Serial 7 in & out?
Thanks..
Jerry Schneider
Re: NavWorx ADS-B Setup with Hx
Post by Jerry Schneider »
I believe the answer is 115200 baud rate
Jerry Schneider
Cozy MKIV N85TT
"I run with scissors"
For the NavWorx ADS600-B
Serial Port 7 Rate: 115200
Serial Port 7 Input: ADS-B
Serial Port 7 Output: ADS600-B
The baud rate is also configured in the NavWorx unit and must match.
The "ADS600-B" output was added in HX software version 5c.
bdtopp
Post by bdtopp »
thanks
330drvr
Post by 330drvr »
Jeff: My Navworx is fed altitude from an HX serial port and the 327 transponder controls the squawk etc. What does selecting ADS600B on the EFIS to Navworx serial out do? I have always had the wire in place, but always in the off selection.
RV-7A
If your NavWorx unit is linked to another transponder, the only benefit of the output is the ability to change the call sign without connecting a computer to the maintenance port.
330drvr
Post by 330drvr »
Thanks Jeff
RV-7A
