EIS 4000 and Hobbs Meter Total Times discrepancy
Teamamey
Post by Teamamey »
EIS does not match Hobbs Meter. Can I change EIS to match Hobbs? If so how?
Re: EIS 4000 and Hobbs Meter Total Times discrepancy
The hourmeter in the EIS can be adjusted in the Configuration Set pages. To access the “Configuration Set” pages, press and hold the center and right buttons until the screen shows “UP DOWN NEXT” on the bottom row. The display will momentarily show the “Set Lean Pt” page while holding these buttons. This is normal. After about 5-10 seconds, the “Configuration Set” pages will be displayed. Press the right button (NEXT) until you see the Hours setting. Use the left two buttons to adjust the hours. When you're done, press and hold the right button (NEXT) until the screen returns to a normal operating page (the screen will stop changing pages).
