On the HXr, Audio Out Hi is pin B24. Is there an Audio Out Lo?
Hooking up to PS-Eng PAC15EX
And I'm guessing the 8 discrete outputs are A6 - A13?
Audio & discrete outputs
Re: Audio & discrete outputs
On some units B25 is audio low. Otherwise use any ground.
On every HX and HXr, B25 is audio ground.
The 6 discrete outputs are B8 through B13. See the attached older connector document (it is still accurate for all HX and HXr).
- HX Display Unit Connector Definitions Rev A.pdf
- (73.14 KiB) Downloaded 1161 times
Ah look at that. Perfect. Haven't seen that doc before. Weird how it never got transferred over to the new documents.
Thanks Jeff for the info.
