HS replacing HXr
jpfli
Contact:
HS replacing HXr
Post by jpfli »
SInce the new HX is replacing the HXr .....
has any thought been given to a mounting plate that would fit the HXr panel opening which would allow the HX to slide right in and mount in the existing instrument panel opening so instrument panels do not have to redone?
Re: HS replacing HXr
We're calling the new products Horizon 10.1 and Sport 10.1, or just "10.1" for short.
We aren't expecting a significant number of customers to switch from an HXr to a Horizon 10.1. If you already have an HXr installed you wouldn't gain much at this point. I'm not aware of any adapter plate plans.
jpfli
Contact:
Post by jpfli »
Hi Jeff:
No current plans to replace but at some point I think it will be cheaper to replace the HXr than repair it, hence my adapter panel thought.
